hey guys
i have a 2 ch amp at home which i inverted one side so i could bridge the channels. now its obviously not designed to run in bridged mode - although it does very well, except it does get a little warm - (ie when you play it hard for a while you start to hear a crackle through the speaker) The RMS output is rated at 30W/ch.
the first thing i noticed is that it has a very thin heatsink on it - especially compared to a car amp i have with about 20w more output power. So is it feasable to bolt another (bigger) heatsink on the output transistors and run it on the 4ohm load??
i have a nice thick peice of aluminium with "grooves" in it which i want to use, but i don't know if its better to have a thick piece of alu or a thin piece as a heatsink. my dad reckons the thick piece will hold the heat close to the transistors.
