I am building a set of Aleph 2 amplifiers, and I have two possible setups for capacitors, and I am not sure what would work better. This is the setup for each amp, and I would have the same on both amplifier.
setup 1: 4 x 30,000 uF 63v capacitors (macintosh ones from brigarelectonics.com $6 each)
setup 2: 20 x 5,000 uF 50v capacitors (mallory, I got them from a local electronics surplus in Atlanta, GA for $0.75 each. I bought one box, which contains 42 of them, and they have about 8 more boxes there.) Would more then 100,000 uF of capacitance sound better? I can easily buy more of these capacitors and make a bigger array.
What is the better setup? Is there anything special to do when hooking up the capacitors, besides hooking them up all in parallel? I would probably make a thick copper strip to run down the capacitor bank.
Thanks for any input,
Brian
[email protected]
Brian
[email protected]
