I have been using Speaker workshop to design my first speaker and had a question about box volume. I am using the Vifa P13-WH-00-08 mid/bass (pair) in an MTM config. I got a box volume of about 1.265 cu. ft from speaker workshop which seems a bit large and two ports 2" diameter.
My question is whether I can go with box volume. I have already built the boxes to about this dimensions (1.29 cu.ft) are they are looking quite huge for the drivers which are supposed to go in. The response graph for the box showed a flat response until about 52 Hz which may explain the size but I would like more input from experts. I know it is a bit too late to change the box dimensions but is there any way I can adjust other parameters or compensate for this, if indeed the box is too big for this set of drivers.
thanks.
thanks.
