Question about Dissipante 2U Internal heighth with baseplate added
If I remember right the clearance between the base plate and the bottom cover is about 3~4 mm.
Internal height is limited by the height of the heat sink which is 80 mm. Subtract the thickness of the base plate and the clearance mentioned above and you arrive at about 75 mm.
Regards,
Oleg
