If one plugs a wallwart into a light dimmer ?
hitsware Member 2002-03-15 6:05 pm Sacramento, California www.youtube.com 2010-09-14 2:41 am #1 2010-09-14 2:41 am #1 If one plugs a wallwart into a light dimmer ? ••• More options Share
D DigitalJunkie Member 2003-04-30 12:52 pm Portland,Oregon www.users.qwest.net 2010-09-14 3:00 am #2 2010-09-14 3:00 am #2 It might work,kinda,depending on the dimmer. Most dimmers can not handle inductive loads,only (mostly) resistive loads. You may also have noise on the wall wart output,due to the 'chopping' of the dimmer. ••• More options Share
leadbelly Disabled Account 2002-12-22 2:13 am Calgary, Alberta 2010-09-14 3:00 am #3 2010-09-14 3:00 am #3 It'll probably work OK if you use the expensive dimmers intended for fluorescents and not the cheap ones for incandescents. Of course you haven't said what you are trying to achieve so it's hard to say if it's a good idea. ••• More options Share
star882 Member 2007-03-19 8:41 pm 2010-09-14 3:49 am #4 2010-09-14 3:49 am #4 A normal dimmer won't work with inductive loads, but a ceiling fan speed control will. ••• More options Share
hitsware Member 2002-03-15 6:05 pm Sacramento, California www.youtube.com 2010-09-14 3:51 am #5 2010-09-14 3:51 am #5 star882 said: A normal dimmer won't work with inductive loads, but a ceiling fan speed control will. Click to expand... What's the differance ? ••• More options Share
star882 Member 2007-03-19 8:41 pm 2010-09-14 2:29 pm #6 2010-09-14 2:29 pm #6 The triac is rated for inductive loads, there's more filtering, and the circuit is designed to always be DC balanced. ••• More options Share
stoc005 Member 2007-02-16 9:20 pm Midwest in the USA 2010-09-14 4:25 pm #7 2010-09-14 4:25 pm #7 Beware of light weight walwarts. They are transformer-less and contain a switch mode power supply. Won't work at all on a dimmer. ••• More options Share
