In part 1 I exceeded the maximum number of pictures so here is part 2.
Undo 8 flat-head screws from the top metal plate and remove it together with the plastic hood underneath it.
Each of the 4 (2805) or 6 (2812) panels are connected with wire links and fastened with 4 self-tap screws to metal side bars.
To remove a panel desolder the wire links at the front and rear of the speaker. The HT line is on one side only. Then unscrew the 4 self-tap screws.
Very informative is the old website of One Thing Audio New Page 1
The two parts of the panel are kept together with 3 spring clips at each side and three bolts/nuts at the center of the panel. Watch the location of the spring clips.
I think that for most people these pictures and the accompanying text will suffice. The reason I took my ESL apart was that one of my diaphragms has a very very small tear or puncture. Therefore I ordered a Quad repair kit from Eraudio in Australia.
