punch 601s bias
Some of the newer amps I have worked on will have distortion in a good channel if there is a bad channel.
Some of the protection circuitry could be damaged.
To set the bias watch your amp meter on your power supply. Screw the pot clockwise just until it starts to draw current then back it off till the current draw goes away. That will be good enough for this amp.
Q1 MMBTA06 "1G" or MMBT3904 "1A" NPN
Q2 MMBTA56 "2G" or MMBT3906 "2A" PNP
Q3 MMBTA56 "2G" or MMBT3906 "2A" PNP
Q4 MMBTA06 "1G" or MMBT3904 "1A" NPN
This was from an 801S schematic, I believe they are the same the 800 just has more parts on the board.
