PS Capacitance
I have seen details of a power supply ( for an LM3875 amp) Which simply consists of a tranny and bridge rectifiers. It seems that it only uses the capcitance at the PS pins to smooth the supply.
Any comments anyone ? I'm just about to lash one up to see what it is like. It is simple if nothing else !
Nuuk. So I detect from your reply that perhaps capacitance on the PS is beneficial/desired ?
No, what I meant was the original Gaincard used 1000uF on each power supply pin and none in the PSU. That's how I have built all my GC's with the exception of the regulated ones. I don't like large amounts of capacitance on an unregulated GC. 😉
there are two schools of thought on powering chipamps.
One uses a conventional PSU that supplies low ripple to the chip and the chip has local decoupling close to the chip supply pins.
Carlos FM uses the conventional PSU but with snubbering.
The other camp dispenses with smoothing caps and sends high ripple supplies to the chip amp and lets the local decoupling do as much smoothing as it's able. Peter Daniel, Nuuk & the original Gain card follow this route.
