gidday, can anyone tell me if it's possible to use a film&slide projector for a projection system. i have a rank aldis slide projector with the following stats, dimensions are 482x298x190
would i be able to squeeze an lcd in there?,cooling is a double action turbo fan which is fairly quiet,optical is 24v lamp 250 watt
type a1/223 tungstan halogen, lumens per sq ft approx 600 plus.
the lens system consists of a reflector,aspheric condenser,2 heat absorbing filters and a front condenser. from about 3 metres it throws a 2m x 1.5m light approx that varies of course depending on the lenses used, this thing may be totally useless but it seems ideal in a lot of ways. it is of course 250 volts ac converted down to 24v for the light, any help would be greatly appreciated
tony
tony
hi
go to www.37.com and do a search for lcd projector plans look down for audiovisualisers.com are something like that it tells the tale of your question
