I have started experimenting with a small-scale solder reflow technique for building SMT circuit assemblies in small quantities. (That's anywhere from one-offs, to a batch of a dozen or so copies.) I am encountering problems when working with the solder paste.
I am trying an electric skillet as a reflow oven. This is described in several online forums and blogs, e.g. "Simple Skillet Surface-mount Soldering" at http://www.instructables.com/id/Simple-Skillet-Surface-mount-Soldering/?ALLSTEPS . I have both a bench magnifier, and a low-end toolmaker's microscope ( http://www.amscope.com/stereo-micro...croscopes/20x-stereo-boom-arm-microscope.html ). Last week I purchased a 35 gram syringe of Kester EP256 solder paste ( http://www.kester.com/download/EP256 Solder Paste Data Sheet.pdf ), a standard lead-based solder in a no-clean flux. I am working with common FR-4 circuit boards fabricated by a respected U.S.-based board house. ( I suspect they are actually fabricated in India, but this supplier has a five-year history of providing boards with no known errors or shortcomings.)
Here's my problem:
I am manually applying the solder paste to the circuit pads, then placing the components onto the bed of solder paste, then reflowing the circuit assembly in the electric skillet. I'm having great difficulty getting the solder paste to adhere to the pads on the board. When I put the small dab of solder paste on the board it almost always sticks to the tool I'm using to place the solder paste rather than to the board. I have tried placing the solder paste with wooden toothpicks, small screwdrivers, pointed stainless "dental probe"-like tools, and small bits of plastic-insulated hookup wire - as well as directly from the solder syringe tip. No matter how I try to press, roll, spread, or smear the solder paste onto the circuit pad the result is always the same: when I pull the tool away, all of the solder comes away with the tool rather than sticking to the board.
Several incarnations ago I did a small amount of work with solder paste, doing repairs and rework on previously assembled boards. I don't recall ever having a problem like this. Quite the contrary, it seemed like the solder paste wanted to stick to the board, or at least leave a smeared mark, at the slightest provocation.
Has anybody else observed this behavior? What am I doing wrong?
Dale
Here's my problem:
Dale
