Problem cd-304 MKII
I have problem with my friend's cd-player.
He has a philips cd-304 mkII and when I push Play the CD start but after 2 second it stop. Evrytime when I push Play, the cd start for 2 second and after that it stop.
What's append?
No movement, but the arm is not jammed.
Usually I know when you turn on the player, the arm go to the begin, read the cd and then the palyer is ready for play the CD.
In this case no, if I move the arm in the middle and then I turn on the cd-player, the arm remains in the middle
Service manual is available via EBay from CAS Eur.10.95
I have found them very quick.
Early Philips cd players suffered from poor soldering on the ground plane which resulted in various faults. Look for what appear to be jumpers with a blob of solder on them. They connect through to the other side of the board. You need to solder a fine wire through the hole, soldering both sides. while you are at it, check for obvious dry joints.
If you can get hld of another cdm1 mechanism, eg from a cd104, you can check the tracking motor by substituting
Andy.
You probably have faulty tracking servo / bad contact / solder joint.
Move the arm in the middle and then turn on the cd-player. Measure the tracking servo signal - it should be substantial - around 2 - 3V to allow for pickup assembly to move close to the center of the CD where TOC is. The CD spins which means that all the switches that have to be open / closed are okay ( T ).
And, check the ribbon cable connecting main PCB and mechanism. It looses connectivity with time - sometimes to a point where mechanism stops working.
Extreme_Boky
There are usually 2 IC's in servo section. One does "calculation" of error, compares it with reference, and generates correction signal. The other is purely high current drive IC - basically low noise OP amplifier(s). There should be at least 3 servo signals going to the mechanism.
I can't tell you "where exactly" to measure servo signals without circuit diagram.
See if anyone on forums has it and is keen to e-mail you the diagram.
Regards,
Extreme_Boky
