For Sale: Pro-Ject Pre Box S2 DAC/Preamp. Dual ES9038Q2M Chips.
The tiny 5v USB power connector broke off, so I just used the other USB connection for power. You can power the unit via USB (Type B connector) and switch to Optical or Coax, or connect direct to computer for USB connection.
Comes with the Type B USB Power adapter and cable. I have a non-stock, programmed universal remote included.
Currently sells for $499 on crutchfield...hows $150 shipped CONUS?
Product highlights:
- dual mono circuitry with two high-performance ESS Sabre DACs (ESS9038Q2M)
- high-res audio playback, including PCM-based files up to 32-bit/768kHz and DSD512
- full hardware-based MQA support
- selectable digital filters
- vanishingly low jitter (as low as 100 Femtoseconds)
Specs:
- frequency response: 20-20,000 Hz
- total harmonic distortion: 0.0003%
- headphone output power: 68 mW (32 ohms)
Inputs:
- 1 coaxial digital
- 1 optical digital (Toslink)
- 1 USB Type-B for connection to a computer
Outputs:
- RCA stereo output (rear-panel)
- 1 front-panel 1/4" full-sized headphone output
