If you are rich, buy a Fostex FW800N, or an Altec or a JBL, buy the best. I's a joke !!!
I think that you are like me a poor boy, so try Beyma 15K200 or 12K200. Very used in France (my country). Here, a 15K200 cost approximately 200 dollars each and 12K200 cost 160. I think that in USA beyma are cheaper.
If you want a real bass box (38Hz -3db to 800Hz). In France an audiophile said to me that he have mounted a 15K200 in a 140 litres bass reflex enclosure, 2 vents 12cm diameter and 18,7cm lenght. The cabinet is made with 22mm board thickness with some "tasseaux"(in french, sorry I don't know in english). In the bottom you fill with sand. On sides you put tar and on right and left you put "laine de roche" (in french, it a sort of absorber).
Behind the beyma, you put a plate/sheet of plumb.
It's a very very good bass box for a 3 ways loudspeaker.
Best Regards.
Pascal.
