Hello friends!
I have a problem with my amp precision power ppi 2125. We connect to 12 volts, remote land and stay on, then turns off and did not want to turn. That could be !?... check all the wiring is fine except that when I run a noise as if something were inside the thundering amplifier.
It does not smell burnt or anything
I'm not sure what you mean. Try using the google translator to translate. When entering the text in the translator, be as descriptive and precise as possible.
