Preamp source select
Im planning to build the esp project 88, as my first complete DIY audio project. Constructing this design shouldn't be a big problem, but if anyone has suggestions, please let me know.
I want to use an relais source select for my inputs, instead of an rotary switch, but I can't find any schematics.
Maybe someone can help me out.
We have an input module which is relay switched. 5 line inputs plus tape in and out plus switched output. Relays take +5 Volts to operate so may be used with remote circuitry. The backplane PCB also contains the phono sockets for convenience. I'll post a picture on the website next week.
Hope that helps, Les
www.users.zetnet.co.uk/avondale
switching inputs by relays
If you can do with four inputs (= four relays) you can control them by wiring 2 double throw toggle switches on the front panel.
i.e. four combinations
00
01
10
11
Each combination switches on a different relay.
The relays can be mounted on matrix board near the input sockets.
This is what I put on my own preamp.
If that is the sort of thing you are thinking of, I can do you a more detailed diagram.
