hi
while im in the mood for updating the old Musical Fidelity stuff i have opened the preamp 8 and it has 4 opamps i think thats what they are ? ZVN4206E 's
what is a better opamp to upgrade this with if any
Thanks very much
Mark
Thanks very much
Mark
pic if it helps
Mark
Mark
If same pin config as NE5532 (Signetics) check out Raytheon's RC4227 -- boy is the noise floor far away
cheers Phase
these are 14 pin type ? ive uploaded a pic but have to wait for a mod to publish as i haven't enough posts i believe ?
Mark
Mark
Hi sparky,
the ZVN4206E is not a opamp. This is a mosfet-transistorarray. 😉
Your preamp is more a diskret-circuit and you can not change the ZVN4206E for a opamp.
ok thankyou moschet appreciate that 😉
so not a lot i can do to improve the pre then ?
its not that its not good already to be honest just a thought thats all.
Mark
Mark
That's a nice looking pre-amp, Sparks -- Just as an aside - I love doing pre-amps using all small signal transistor discretes, like Naim -Krell - Levinson etc -
it's ages since I used preamp packages
It's really interesting how much this piece of **** costs.My DIY preamp is ways.. better then this garbage.
If you feel like giving this a bit of a lift maybe you should try recapping the preamp with high quality capacitors such as Elna simics and/or Panasonic FC.
http://www.diyaudio.com/forums/parts/151392-best-electrolytic-capacitors.html
You could also look at the PSU circuit and regulators.🙂
cheers Xoc1 excuse my ignorance in these matters,
The way i have this set up is :
cdp or playonHD! streamer thingy TO Dac TO preamp TO monobloks
so what does the pre do ? does it just pass thru what the work that the dac does onto the amps or does the preamp alter the sound at all ? really sorry for the poor terminology 😀
Mark
Mark
The preamp in your set up is just being used as a buffered volume control,
The preamp probably blocks any DC and RF and ensures that the power amp is driven properly at any volume setting, by driving the signal with a low impedance to minimise losses due to the interconnect cables to the monoblocks.
- preamp opamps
