Preamp Impedance Question
I've made a preamp incorporating a fiio d3 dac. The potentiometer I am using is 20k. It was fine when I was running the RCA's 6 feet from the DAC to the pot; but now that I have the d3's board directly soldered to the potentiometer with 3 inches of wire, the potentiometer volume range is very tiny and really uncontrollable.
So I added at 10k, 10k film resistor voltage divider for each channel between the D3 DAC and the potentiometer. This solved the volume range problem--it's quite nice and controllable.
My question is, should I be using the10k, 10k voltage divider before the potentiometer or should I make say a 500 ohm, 500 ohm voltage divider?--i.e. if the output impedance of the DAC is 1k ohm.
Would really appreciate an answer since I am newb and trying to wrap this little project up 🙂 Thanks so much!
