Welcome all members
I say at the beginning of the writing in Bascom
I wanted to do pre-amplifier based on PGA2311
I should add that I want to have a watch based on the PCF8583 and thermostat on DS18B20 to control the cooling power amplifier.
The problem I have with writing code,already wrote the beginning but does not work properly.I mean I can not do that thermostat to act at all times in my program so it works with only after entering the program begins to work TEMPERATURA but when you move to a different program from the menu stops.As for the PCF8583 I do not know how to convert a set time and date so I can control the switch and encoder
For PGA2311 has not figured since I have a problem with the first part of the code may be one of the more experienced maybe something to help me
adds code
adds code
Hi Mario
I have seen your you tube video and commented on it. I think what you have made is beautiful but we need to keep Time as Standby and present input and volume as primary.
if you do it it i could test as i have a setup
cheers
Welcome all members
adds code
cheers
