Working with the 6J6 data spec pages...
Gain is lower, operating point similar, 5 ma running current. Gotta watch that 6.8K anode resistor: P = E^2 / R = 30 x 30 / 6800 = 1/4 watt. But if you choose a lower plate voltage (say, 100V instead of my 150V), then the voltage across it is now 80 volts, so P = 80 x 80 / 16,000 = nearly one HALF watt. Bigger resistor, of course.
Same goes for the use of higher B+ voltages (to increase gain mostly). Just make certain you do the power-dissipation calc for the poor anode resistor. Its the one taking the brunt.
ATTACHED is the modified drawing, with typos fixed.
GoatGuy
