Pre & PowerAmp Case Group Buy
I am going to be buying 3 cases from thlaudio.com, 1 pre-amp case and 2 stereo chassis for my amplifiers. Before i purchase them, i thought i would ask if there are any people's on here that are looking for some VERY nice looking cases. I will be handling the purchase and shipping to each person. You can buy one case or many cases. This is not to make money for me it is to help out other that may want one. I will be able to get other cases they sell if other interested, HOWEVER you will pay EXACT shipping for the case-'s.
Their case design site is, Chassis case item
pre-amp case is,
RAL-30267 All Alum. Chassis for Pre. amp.
Overall size: 30cm(W) x 26.6cm(D) x 7 cm(H)
Face Panel: 30cm (W)x 7 cm(H)
Thickness: side board/front board at 8mm, top/bottom board at 4.8mm/3mm
Pre- cutout/hole:
- Front Input Select and volume control, recesses of 30.5mm Dia. x 5.5mm(Depth)
- Led hole: 3mm dia
Back Panel Pre-cutout/hole;
- INPUT: 4 hole or 2 sets for inputs(11.8mm dia)
- OUTPUT: 2 hole for Pre. out(11.8mm dia)
- Power socket😱f 28 x 20 mm cut out , with 2 fixxing screw hole
- Power Switch cutout😱f 14 x 20.5 mm cut out, for snap-in type
- fuse hole in 12mm dia.
Finish: hair brushed in anodized plating in black and natural finish
net weight: 3 kgs
Power amp is,
PWAD-A40 Alum. Chassis for power amp.
Heat sink suitable for 30W+30W stereo or 60W under Mono Class A,
Overall size: 48cm(W) x 26cm(D) x 11cm(H)
Body size; 47 cm (W) x 25cm(D) x 10cm(H)
Panel size: 48cm (W)x 11cm(h)
Thickness: body(1.1mm), panel (6mm)
Heat sink size: 25cm(D) x 10cm(H) x 3.5cm(Thick) , with
2 pcs of heat sink
Pre-cutout/hole:
Panel Main switch; 23 x 13mm( recess 38 x 23 mm)
Led hole: 3mm dia
Back Panel; 2 hole for inputs(10mm dia)
2 set of speaker out(each with 4 hole of 10mm dia.)
Power Switch: 28 x 20 mm cut out
fuse hole in 12.5mm dia.
Finish: alum. alloy anode plating in champagne. top, bottom & rear panel in baked steel with printed indication labelling.
Questions comments can be posted here or a simple pm, if u wish.
I will post pircing tomorrow after my phone call with lee.
jleaman:
I'd be interested in a chassis for a small power supply -- either OPS-op4-B or OPS-OCT4-B, depending on the price. Any chance you might be able to add one of these to your order (assuming the price is right)?
Regards,
Scott
I recently ordered one of their PRAL-47328R cases (rounded corners, natural aluminum). Shipping was lightning fast to Arizona. Solid as a rock. Fit was not bad at all.
I am happy enough that I just requested a quotation for a second matching case to mount power supplies in.
Ken B
