Ok so i need to build a pre-amp chassis. I have a Aleph p.17 I’m going to use with all balanced output's and also rca output's. My question is, what would be better or smarter in my thought process.
A pre-amp with the 3 active x-over's built in with xlr / rca out puts so 8 in total.
Or
A pre-amp with 2 main in's * source's * and 1 set of out's rca / balanced. Then another box with the active crossovers in it.
There will be 8 channels maybe 6 channel's.
Left channel & right channel
Hi
Mid
Low
Sub’s
So on the active x-over if it is separate it will have 4 left outputs and 4 right out puts. And one set of input’s from the pre-amp
So my question is should I make this one big preamp with all these goodies internal or should I make the pre-amp then a separate box for the active x-over’s
Or
Hi
Mid
Low
Sub’s
