PPI Pro mos 50/Sedona/MTX Terminator MTA250 5 pin Molex plug sucks, any better solution for replacement?
This same plug is on the MTX Terminator 250. Made by PPI. I have one and love it and still use it in my vehicle, running 400 watts mono into two subs. THe issues the that amp and this one is that samn Molex connector for the speaker wire, etc. Is there now a better way to replace that? Mine is sporadic and i temporarily fixed it by putting a nickle squeezed in beside the plug and working so far )this put the needed pressure on the plug I guess.
What's the easiest way to replace this today? 5-way binding post? What will work?
You can open the connector, remove the pin and bend it to put more tension on it. They have a silver coating so you may want to remove any excessive oxidation (although it will likely self-clean when it has better tension).
A common temp fix that does no harm is to run wires out of the amp (after removing the factory connectors) to a terminal/barrier strip and to make the connections on that strip. It's not a beautiful solution but works perfectly.
