I am not certain whether the speakers I have will work with my Powerpod K12 plus.
I have two speakers rated at 8ohm each (300W).
If I run the amp in 8 ohm mode with each speaker connected to a separate channel, is it safe to do this?
The amp has 2 channels - 500w / 4ohm
And I think it is 300w / 8ohm
Hope you can help - I don't want to damage anything at our next gig!
Thanks,
Jon.
Thanks,
Jon.
I'm not familiar with this Powerpod K12 is it a solid state or tube amp? Can you post a link to it?
If it's a solid state(transistor) amp then it's perfectly safe with any speaker load above the minimum rated load, so one 8ohm speaker on each channel is fine.
the Powerpod K12 is a mixer/amp that's made by Phonic.
without telling us what your speakers are;asking to qualify something on just a power rating might not be the answer/advise you need.i can find a number of drivers with that spec but because of type, size, or other factors like the type of box would make them unsuitable as a P.A. speaker.
jomaco as far as getting through your next gig without damaging anything careful setup and avoiding feedback are key elements to success!
