Hello Everyone
I have been thinking about what I want to do in terms of audio in my bedroom, and I decided that I will try this. I know it is a bit insane but it has been done before, and this is exactly what I want to do.
Okay so I found this other posting board (forum), and a user posted the following:
_________________
I went out and grabbed 3 lead acid car batteries from a junk yard for $5 each. They all worked enough to hold a charge and start a car.
I checked the water and electrolytes in the batteries and made sure they were up to par.
Went to a truck (big rig) supply store and bought heavy guage wire and battery terminals. They are MUCH cheaper here than at an car audio store. Compare 3 or 4 dollars to 35 or 40 for wire. I also picked up a 12 volt battery charger that had settings for "trickle" 3amp 5amp and 10amp. Total spent so far was around $65.
Set all 3 batteries on a piece of wood. Avoid concrete or carpet. Concrete is bad for the battery and carpet isn't good if the battery leaks.
Wire all 3 together in parrallel. That's positive to positive to positive to amp positive and with another (different) wire hook negative to negative to negative to negative of the amp. Now hook the charger to one of the batteries.
Use a small piece of wire to connect your "remote" lead on the amp to the positive of the batteries and your amp should start right up. Leave the changer in the trickle mode at all times and you should be able to jam for hours on end without pulling the batteries too low. When you are not using the amp remove the "remote" wire and they charge back up.
_________________
...now, I know that it seems like a big hassle etc, but I really want to do this and need some help. If I did the same this guy did, except buy brand NEW equipment, 3 car batteries (12volt +), a battery charger [just plugged in at an ordinary house wall plug outlet], and the necessary wires/leads - would it actually work?
I have a Pioneer TS-W5000SPL Subwoofer, a Pioneer PRS-D5000SPL Amplifier and a SPL Optimized Ported Enclosure Subwoofer Box. I need to purchase: home studio speakers (x2), a car head unit and the rest of the necessary equipment to make this work. Whatever other equipment I need, please let me know.
The subwoofer is EXTREMELY powerful at 5000watt/2000rms, and the amplifier can handle a maximum of 3000watt/1500rms. This is a concern to me because I don't know whether those 3 car batteries will be feeding this amplifier/subwoofer enough power (or whatever you want to call it in the world of physics, amps?) in order to reach it's full potential. I don't want to limit my setup to perform under it's full capabilities, whether it be because of the car batteries, or whichever piece of equipment - it would suck.
Full specifications on the subwoofer and amplifier can be found here: Amplifier (Pioneer PRS-D5000SPL) and here: Subwoofer (Pioneer TS-W5000SPL)
Please give your constructive thoughts and suggestions/input, that is what I am looking for.
Thank you very much in advance,
Johnny
_________________
_________________
Johnny
