Hi there, I built a 18 v -/+ split supply using 7818 and 7918 Ic`s. The wiring is correct on the smoothing capacitors(1000mf) on the intake side. When I measure voltages on the outputs I get 18v on the positive side and 24v on the negative side (no load ). Shouldnt it be the same voltage?
