What power source do you recommend for this? greetings and thanks
NE5532 * 24 ultra baja distorsion 12W*2 Auriculares Estereo Amplificador Board Para Estereo | eBay
Coro 48 NE5532 * 24 ultra baja distorsion 24W Amplificador Board para auriculares estereo | eBay
2.0 * 16 Chorus NE5534 C 16 ultra baja distorsion 4W+4W Tablero De Amplificador Para Auriculares | eBay
Nueva fuente de alimentacion de alta velocidad salida Ultra bajo ruido regulador lineal nucleo de potencia para amplificador HiFi CD DAC T0158-in Amplificador from Productos electronicos on Aliexpress.com | Alibaba Group
how do you see this
along with two of these in parallel?
Transformador de PCB, 2 x 15V ac, 2 salidas , Montaje en PCB, Potencia 30VA | RS Components
how do you see this
Hi Andres,
Sorry, I made a mistake. I meant +/-15V 2A, not 1A. But, there is more to it.
Let's assume you use the most heavy load of 6 Ohm. We assume the NE5534s can do an output swing of 12V. That means, the maximum current in one speaker is 2Apeak. That is a peak value, not effective value. Worst-case the two amplifier channels may be in phase at full (clipping) power. 2Apeak for each channel means 4Apeak for the two channels (worst-case).
Big electrolytic capacitors have the ability to buffer (average) the dynamic current-needs to the load such that only the average current needs to be supplied to the electrolytic capacitors.
This is the case for unregulated power supplies with large rail capacitors. Then, 2A average from the transformer will do with margins.
If you have a voltage regulator before the amplifier, such as you show in a first example, the large electrolytic capacitors are connected before the voltage regulators and little energy storage is found at the output of the regulators. In such case, the voltage regulators need to be able to supply the full peak-current without invoking the current limiters. The total peak current we found to be 4A. I do not know this regulator board or the regulator ICs but I doubt they can do 4A before current limit.
I will return in a following mail because my dog insists on a walk..........
Hi AndresTC,
..........I'm back but with a 2nd posting, not a mail.
I looked at the performance of the NE5532 and there is something I cannot make fit with what the advertisement of the board says.
NE5532 is a double OP-AMP. The board shows 24 ICs, thus 48 OP-AMPs in total. The output short-circuit current of an NE5532 OP-AMP is in-between 10mA and 60mA (quite a span). A typical output short-circuit current is 38mA but short-circuit currents are at zero voltage. However, it leaves an idea about what order of current we can expect from each OP-AMP.
A more relevant information is that with a +/-15V supply voltage and 600 Ohm loading, a total output voltage swing of 26Vpp is likely. 26Vpp is 13Vp. 13Vp in 600 Ohm means a peak current of good 20mAp.
If all 48 OP-AMPs are used for a single mono output, close to 1Ap is obtainable. 1Ap in 8 Ohm gives 4W and a peak voltage of 8V.
Mark is right that the NE5532 can be used up to +/-18V but as the board lacks current capability with normal speaker impedances (up to 8 Ohm), it is little useful to increase the supply voltage.
The advertisement is giving very little performance facts. 2X12W seems unattainable whatever way I look at it. The OP-AMPs can be split up in two groups with 1W in 8 Ohm for each but that is hardly very useful for the size and price of the board.
The advertisement describes in more places the use with a headset. The board has the power potential to drive heavy headphones but similar performance can be made much more compact and at a lower price. Most output power with common loads is in 32 Ohm. But several Watt (around 2x3W) for a 32 Ohm headphone seems excessive to me.
I cannot figure out what is the practical intention with this board. As I cannot tell the realistic use, I cannot advice what power is needed from the power supply. If you buy the board, a +/-15V or +/-12V power supply with 1A or even 0.5A is good for playing around with the board.
My previous calculations were based on that the board could deliver 2x12W in 8 Ohm (at least). As I see it now, it can’t and please forget about my previous estimations.
then the 5534 4w + 4w of how many w will be hehe..
In any case it is to attack a beyma tpl150 and beyma 6mcf200 both are very sensitive of 100 db.
then this more this It is more than enough
AIYIMA 20A amplificador de Audio de alta potencia filtro rectificador de Puente unico PCB fuente de alimentacion DIY-in Amplificador from Productos electronicos on Aliexpress.com | Alibaba Group
Thanks for the answers !!
One transformer like the one you show and one of these:
Placa de alimentacion lineal de doble regulador LM317/337 + TL431 +/ 5 V a 37 V a envio Gratis-in Adaptadores AC/DC from Productos electronicos on Aliexpress.com | Alibaba Group
Should do the job.
The AYIMA 20A board you show is for a real power amplifier and not regulated. With that transformer, the voltage will be too high.
Should do the job.
I guess this would also be valid
spm=a2g0o.cart.0.0.1c5d3c00ygOwJk&mp=1
thank you very much for everything!
Both. LM4562 can generally replace NE5532. LM4562 only accepts +/-17V as supply. Use IC sockets when you remove the NE5532 (I now see that they are already in IC sockets). Removing all the NE5532 is quite a job. With LM4562, the total idle current should be around 250mA so the voltage regulators may be warm.
replacing 5532 with lm4562 in this case .. the sound is quite distorted maybe the source not the size for those 250 mA
Mshow tienda de audio linkwitz reilly Crossover 3 vias divisor de frecuencia electronico HIFI Preamp audio-in Amplificador from Productos electronicos on Aliexpress.com | Alibaba Group
spm=a2g0s.9042311.0.0.7df463c0srLjCm
Lusya 3 vias Crossover PCBA ClassA Power linkwitz reilly filtro 6 canales punto cruzado 310 HZ/ 3,1 KHz G1 004-in Amplificador from Productos electronicos on Aliexpress.com | Alibaba Group
- Power Supplies
- power source??
