If I am building A P3A for the low pass, can I build a well matched biamped system with a P10 as the high pass amp? More specificly, what Xover frequency would I need?(assume a Linkwitz-Riley) I have some POS speakers for the mids and tweeters, but the subs are MTX Thunder3000's. I know NOTHING about the POS speakers, but the MTX's are marked:
1OMC1280 4 OHM
557 99-05-24
Is this (model#, impedence)
(datecode) ???
Jake
1OMC1280 4 OHM
557 99-05-24
(datecode) ???
Jake
If you know nothing about the POS speakers, you might be best off to build your amps, and an adjustable crossover, and adjust the levels of the amps and the crossover until it sounds good.
