Power Acoustic BAMF 5500/1 D
got another one of these amps..
There were 2 outputs blown so i removed them and tested the rest of them they all tested fine..
I replaced the 2 outputs so i could further test the amp before i replace all the outputs with new..
All the drivers tst fine as well but with the audio driverboard in the amp it will draw excessive current.. if i remove it and power up the amp it idles fine..
Does anyone know what drivers may be suspect on this board?
Did some more trouble shooting on this amp..
If I have power,ground,remote hooked up the amp will power up and idle fine ..
As soon as I try to plug in the Rca's the amp will draw excessive current ..
I checked the shield ground for voltage but it was at 0.00
Anyone have any ideas why this amp draws excessive current as soon as I plug the Rca's in ?
