Polarization Woes
I made a ghetto overhead projector, but when I stick my LCD over it I see no image. Now, If I stick a cheap polarizing sheet between the LCD and the OHP's fresnel, I'll see an image but the colors are all flipeed! No matter how I rotate the polarizing sheet, the colors are messed up :hot:
Is this a problem with my polarizing filter?
EDIT: one more question, I found a working 400W MH light w/ ballast for $20. I've read that the 250 Watt MH lights usually work better, but I havn't found any 250 watt bulbs w/ ballast for this little money! Should I go for it?
What brand LCD is it?
When you took it apart what exactly did it come with? Meaning polarizers? Normally they come with a reflective polarizer between 2 defuser sheets.
400w MH bulbs are fine... just dont use one with the big huge hump. I've used the old hump MH 400w, 250w HQI double ended and the thin 400w MH bulbs. The big thin 400w MH bulbs are THE BEST!. Not only are they more then twice as bright as HQI bulbs but you can use them with a spherical reflector and condenser! (I cant wait to post pics of my setup🙂 You have to remember. It's not the size of the bulb that matters... it's the arc length. 250w HQI bulbs have about a 23-25mm arc length. The big thin MH 400w bulbs (at least the one I'm using) has a 27mm arc length. Not much difference.
