Polar Measurement setup
If I were to make accurate polar measurements, I don't see a need for anything more complicated than a large lazy susan bearing and two sheets of plywood with degree markings every 5 degrees. They do make automated turntables and I suppose it wouldn't be terribly hard to make some PIC based motorized turntable rotator, but why?
My lazy susan/MDF was easy but its the 5 degree markings that I SUCKED AT 🙁
Place the box on a disk to make the angle. The center of the dome is the vertical ax of the rotating point.
polar I think is not very informative.
Measure the whole range under a angle.
0,15 ,30, 45 degrees
