plz check my ported box math.........
Yes, as GM notes, the calculations come out closer to 32 Hz, but what's 1 Hz?
However, many (most?) calculators use end correction factors for one end flush mounted and the other end free. Not sure how Horn Response works. With that in mind, a 2" hole in a .75" or .625" wall may still be close to 32 or 31 Hz, but difficult to adjust the "length".
The Loudspeaker Design Cookbook also references a (conservative) calculation for "minimum" vent diameter, based on driver Sd and Xmax. For an 8" driver, a 3" port might be a better choice.
