Hi guys..i'm newer in this group.....i need your share about my new project.i 've buy a 2x100 watt class d 4 ohm amplifier.but,this amp no volume controller.so,i've buy a alps potentiometer.at the same time,my problem still not solve because i dont know how to put this potentiometer to this amp....i dont know where is L /R at the leg of potentiometer for me connect from rca ...somobody can help me?plzz guys....i'm still study about diy amplifier...
THIS IS MY AMPLIFIER CLASS D 4 OHM BY SURE ELECTRONIC:
AND THIS IS A VOLUME CONTROLLER THAT I WANT TO PLUG IN:
Post #46 here should make it clear. The connections are the same,
http://www.diyaudio.com/forums/analog-line-level/167495-simple-stereo-gain-stage-3.html#post2223625
Alrite....tq bro....tq so much....i will survive the project better than before....
at the port of RCA female,where is positive(+) wire? can u show me?Post #46 here should make it clear. The connections are the same,
The centre connection is the signal carrying connector and the outer part is ground for all RCA connections.
So the outer part (the ground) of all the RCA sockets should be connected together to maintain continuity and these also connect to the "pot ground" connections that I showed in the diagram in the link. Yes
alrite...tq bro...one more question...the ground at RCA connector are same with ground at the board or not?The centre connection is the signal carrying connector and the outer part is ground for all RCA connections.
So the outer part (the ground) of all the RCA sockets should be connected together to maintain continuity and these also connect to the "pot ground" connections that I showed in the diagram in the link. Yes![]()
Yes, RCA grounds connect to the signal or input grounds or the amp.
- Class D
- Plug in potentiometer for 2x100watt class D amp
