Please could you look next pictures
and
and tell me do you recognize which model of Laser Pickup is on those pictures. I can tell you that only what I know about it is name "CMK-81".
Any information will be greatly appreciated!
Regards!
and
Regards!
CMK-81 is written on the PCB but I don't think it refers to the pickup model.
What is the brand & model of the player?
/Hugo
/Hugo
This is from Sansui CD Alpha 907 (Japanese market), for international market was Sansui CD-X901. I think they are the same. Both models are from the year 1987.
Regards!
Regards!
Must be a rather rare player, I can't find any info in my database.
You might also try here:
http://www.audiokarma.org/forums/forumdisplay.php?f=39
/Hugo
/Hugo
Thanks Hugo, but I am already member of that forum, and please take a look on this threadNetlist said:Must be a rather rare player, I can't find any info in my database.
/Hugo
http://www.audiokarma.org/forums/showthread.php?t=125444
I am Kale on that forum😀 .
Can you recognize model of pickup? If you need I can send you more pictures.
Regards!
Zeljko,
You can search in this gallery, or even ask them for assistance:
http://www.ersatzteil.justone-schnepel.de/html/bildergallerie1.html
Sansui used KSS210A and KSS152A in other models, no idea about this one. Look for a paper sticker on either side.
More pictures
This is bottom view
This is view by side
And this is top view
This is bottom view
oshifis said:Zeljko,
Thank you for that site, I emailed to them about this pickup. I didnt find anything similar to this laser on that site 🙁
It seems that it is some custom made Sansui laser pickup 🙁
Regards!
Is it dead? If you can see some red light, you can try carefully adjusting the pot (nothing to loose).
No I just got it, and I cant try it because it is 100V AC unit (Japaneses AC voltage), and I am waiting to receive one step-down trafo 220V to 100V AC. In meantime I am searching for that Laser, because it is too old, and I can expect problems with it. Because of that I wish to buy some new one.oshifis said:Is it dead? If you can see some red light, you can try carefully adjusting the pot (nothing to loose).
I have original Service Manual for it, and I am going to make some restauration on it (recap and other things...)
Regards!
I'd wait to see whether you actually have an issue before worrying too much about the laser. This mechanism looks like it might lend itself to transplanting something else. There is a thread here that shows how to transplant newer laser assemblies into a variety of older players - might provide some inspiration:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=111364
My cheap 17 year old Sony is still working fine (in a new home now) after many thousands of hours (5K+) of use, OTOH my old (but much newer) PS Audio Lambda Drive with Philips CDM-9PRO died at well under 2K hours.
I keep thinking this might be a very early Sony derived mechanism based on some very early Sony players I've seen, but I could be dead wrong about that.
kevinkr said:I'd wait to see whether you actually have an issue before worrying too much about the laser. This mechanism looks like it might lend itself to transplanting something else. There is a thread here that shows how to transplant newer laser assemblies into a variety of older players - might provide some inspiration:
Thanks for that interesting thread
Again, it can be good, but if not, I would like to find source where I can buy it.Originally posted by kevinkr
What is strange, in many sources I have found for Sansui CD Player CD-X701 has KSS152A, and on some sources I have found that CD-X901 has KSS152A too, but for sure this is not KSS152A
Regards!
- Digital Source
- Please look that Laser Pickup...
