Please help me to chose the right enclosures for these 12" speakers:
Impedance: 8 Ohm
Minimum frequency response: 31Hz
Reproduction frequency response : Fo - 17K
SPL: 94,587db/W(m)
Rated Input: 30W
Music Power: 45W
Equivalent diagram radius: 135mm
Equivalent mass: 29,786g
Magnet wight: 1350g
Net Weight: 5050g
Fs: 31.24Hz
Re: 7.2 Ohm
Mms: 36.331g
BL: 9.810TM
QTS: 0.495
QMS: 6.907
QES: 0.534
Vas: 259.741
Xmax: 1.0mm
no: 1.435%
Thank you!
Impedance: 8 Ohm
SPL: 94,587db/W(m)
Rated Input: 30W
Music Power: 45W
Magnet wight: 1350g
Net Weight: 5050g
Fs: 31.24Hz
Re: 7.2 Ohm
Mms: 36.331g
BL: 9.810TM
QTS: 0.495
QMS: 6.907
QES: 0.534
Vas: 259.741
Xmax: 1.0mm
no: 1.435%
Thank you!
