Please help me select drop-in replacement for HiVi B3N 3" driver -
I wanted $25 / driver, but can't find. 83 mm / 3.26" bolt circle. I came up with some, but no experience with them. In compact transmission line. Anyone have a recommendation among the following, or something else?
This might be the sweet spot: https://www.parts-express.com/Dayto...es-Full-Range-Driver-8-Ohm-295-422?quantity=1
It's a direct drop in. There's an aluminum cone for $25 and a paper cone for $15. I'm tempted just to order them! Better than HiVi B3N? The B3N has the flaws listed in reviews, shouty etc.
Alternatives that wouldn't make me flinch too much, but would need to be a bit of a jump in performance above the DS90:
Tang Band W3-881SJ 3" Cast Frame Neodymium Driver $46 slightly larger, but I believe I can fit it.
Tang Band W3-2141 3" Paper Cone Full Range Driver 8 Ohm circle $60
Peerless by Tymphany 830986 3" Full Range Woofer $50 excellent reviews, but no bolt circle data
Fostex FF85WK 3" Full Range $54
W3-1364SA - 3" Paper Full Range - TB SPEAKER CO., LTD. $60
I wish a Mark Audio would fit.
