how much ampere do I need for sustained plasma arc/corona? I found the numbers for volts,I see people using these high voltage flyback transformers,they have thousands of volts and not much amps...
I want to use minimum amount of amps possible,so lets say I have 80 kilo volts,how much (mili) amperes do I need with that 80kv to get plasma?
