I have a Placid BP that works fine on the +rail be the - rail starts at 15V then looses 0.1V every couple of seconds finally bottoming out at around 9V.
From then on tweaking the adjustment pot makes no difference.
Any idea why?
Any idea why?
Something had definitely died as the voltage across VR3 varies with its ohm value. AFAIK this should match Vref at around 4V.
May be a transistor or one channel of the opamp has died.
Any ideas how to test for which?
Usually this is a transposed component. Look for transistors that may be swapped.
Also are the LED lighting correctly?
Continue this on the support forum with pictures if possible. Thanks.
Any idea why?
I have had very similar thing with mine...
I just tapped on the trimpot few times with my index finger and ever since all is fine 😀
