pl504 Vacuum tube
hi,
I designed this circuit in Multisim but there is a voltage drop in transformer. I think there is a problem with a transformer model.
can any one help please
here is the circuit reference : http://www.gtlab.net/gtlab2/filemanager/userpix/igor/low_anode_2.pdf
I built this circuit and it's working I used this transformer
I appreciate your help thanks
Actually, both your model's figures and your results are likely correct.
Your audio transformer probably has a primary DC resistance of around 300 ohms, so feeding 33mA through it will drop about 9 to 10 volts.
In the article, they use a big transformer, likely with a primary DC resistance around 30 ohms, so they will only drop 1 volt.
You solution could be to use their transformer, or feed a voltage of 37 or so volts to the top of the transformer you have. Either will give the near 27 volts on the anode.
Gary
I just checked on your Adastra transformer, and it is an audio type which will have a high impedance, so you are not likely to get much power out of the circuit with it.
The article used a mains transformer which is much lower impedance on the primary side.
