Hi All
This amp uses two of the PA 0016 voltage amps, one channel has bad distorsion,
If i switch IC PA 0016 from the channel that is working the bad channel isworking fine with no distorsion,
I have replaced the bad channels with new PA 0016 IC but it is not working so i suspect that the PA 0016 i hve bought from ebay is fake has someone had similat problems or is there any mods I am sure if i could find a NOS PA0016 from the eighties it should work or am i missing something here
Any hints or info greatfully received
Regards Greger
Regards Greger
