Dear gents,
in the last few months I have been attracted by vintage amplifier designs. I have read here a couple of threads by forum member Lineup describing the simulation process for a Leak Delta 70 and a Dynaco ST-80.
Using similar devices I have tried to simulate the power stage from a Pioneer SX-6000 receiver , but simulation result is quite bad. The reason for choosing this design is that I have a power supply capable of supply 54V that matches the required value for the original model. my first attempt was to clone a Sony STR-6120 but it appeared to be very complex to my level of expertise ( close to zero ).
I have seen that STV-3 is an obsolete device , and tried to use 3 x 1N4148 instead. Tried to use a VBE multiplier before with worst results.
I would appreciate some guidance for my next steps.
thank you
thank you
