Hi wiseoldtech,
Maybe harsh, but for very good reason. NTE seems to work okay most of the time for TV guys, but certainly not for audio service. For one, you have zero idea what that part is really, and you can't match them well for the simple reason that you don't always get the same transistor before they erase the markings and put their own number on it. You may get a match at a certain current level, but since they could be totally different original parts they won't track well. Then there is the question of complimentary parts. Sure, they list them as complimentary, but the other transistors may not be proper compliments - never mind even the same transistor.
I have had a high number of repairs with NTE parts that had weird faults, and I learned to test the NTE parts first, and was very often rewarded by finding the problem part right away. This includes blown outputs, noisy amplifiers and other faults similar to this. The only time I will use an NTE part is when the original part is NLA and there is no substitute. This usually means a specialized IC, like an MPX decoder. The only reason I will use an NTE there is because they pretty much have to use the real part.
Price. Well, because I am spending my client's money, I do care how much the part costs within reason. I won't risk finding a less expensive part for quality. I'll pay the proper going rate for parts, but I won't over pay and that is exactly what you are doing by supplying an NTE part.
When I recommend a shop for anyone who asks, one of the things I tell them is to look around to see if they see any ECG / NTE or other replacement brands, turn around, walk out and never come back.
wiseoldtech, while you may be different than most of the folks I know of that do use NTE parts, the vast majority of NTE users simply don't understand how things work and how to fix them properly.
No offense intended here.
-Chris
