Pioneer GM-X962
The amp had shorted Mos-fets which I replaced. At idle, it draws about 1/2 amp and appears fine. After about 2 minutes it gradually increases current draw and the left channel output transistors get hot at which point I shut it down. I pulled the output transistors and they check out fine. I even replaced them as I had some NTE equivalants and the same thing happens. Any idea where to go from here?
