Pio russian capacitor K42-11...is good ?
K42Y-2 are metallized paper in oil but K40Y-9 are metal foil,paper in oil. Both are excellent(if you like PIO;not everyone does)and beautifully constructed, although,in theory, the K40Y-9(much bigger) should be better.
The different suffix,11, may mean it is a variant for special purpose,for instance,high frequency use. I am sure some member of the forum will know this.
Actually, I have just looked at the ones you mean(which I have not tried) and they seem to be large value lower voltage without the usual glass sealed steel case.
I did not see post number 2- yes,probably no oil!
K42Y-2 is a PIO capacitor ?
Friends
Some time ago I got a lot of K42Y-2 tubes in ebay.
I make a comparation with a old ( 60´s) brazilian made PIO capacitor( the brand make this oil capacitor until today here) and the brazilian sound best...this K42Y-2 is really PIO or for the russians sellers PIO is Plastic In Oil ?
In ebay have a confusion and few information about the material used in this russian capacitors...
Aldovan
Here is some info from Russian book:
Low voltage, low frequency caps:
Paper: КБГ (КБГ-И, КБГ-МН, КБГ-МП), ОКБГ (ОКБГ-И, ОКБГ-МН, ОКБГ-МП. ОКБГ-М), БГТ, К40П-2, К40У-5, К40У-9, К40-11, БМ-2, БМТ-2
Metallized paper: МБГ (МБГП, МБГЦ), МБГИ, МБГН, МБГО, МБГТ, МБГЧ (МБГЧ-1, МБГЧ-2), МБМ, КМБП, К42У-2, К42П-5, К42Ч-6, К42-4, К42-8, К42-11, К42-18, К42-19
That's all I can find
Wavebourn, no need to apologize for your English; your written skills are much better than the verbal skills of many native American English speakers I know. 🙂
I recently completed a VTA ST-70 build, and I went with the Russian PIO cap upgrade. I can't say they made a difference as I didn't hear the amp before installing them. I can say the amp sounds very nice. I was struck by their physical size though. They're relatively huge!
I have used either K75-10 or K75-24 in every amp I have built but always as either bypass caps for the power supply electrolytics or in the snubbing network in choke input PSU. I think it would be hard to find better caps for this purpose.
I guess they might also be suitable for parafeed caps.
Ervinl; K40U-9 and K42U-2 are available up to 1600V. Excellent eflog seller Dmitriy Kolevatov (user name uralspirit) has good selection at higher voltage and is happy to sell small numbers.
