Look nice, especially like the P-P. Looks like you have rotated them through the same system, I would like to read what you hear as differences between the two.
Matt
Matt
the SET amp definitely colors the sound, like that 50s clean guitar sound, but it is nice and the bass is very full for a small little amp like this. the PP is 3.5 watts vs the 1 watt and sounds more accurate. im still waiting to put in some better bypass capacitors on the cathodes. the ones i put in are low quality. i probably prefer the PP, it is clean and very HIFI to my ears. on fred's web site he compares the outputs and the harmonic frequency graphs and the PP is much lower in first order harmonics and the output frequency wave is almost identical to the input signal whereas the SET it is somewhat rounded.
thanks for commenting.
Graphs are not the best indicators of sound. I've been wanting to do a little P-P like that so I'm encouraged by your comments. Depending on how efficient your speakers are the SET could be straining a bit. My 6EM7 SET sounds great on La Scala but sucks on mini monitors.
Matt
Matt
i'm running them through a pair of celestion 5s vintage speakers they are about 89dB and it sounds great to me. yeah some of those very sensitive klipsch speakers would be fine but not necessary for my needs.(it is tempting though)
if you build the PP have fun and enjoy it does sound very good.
Excellent job! I like the look.
I've been gathering parts for the pp version myself as a first shot at building a tube amp. What did you use for an output transformer?
BTW, if you need tubes, Surplus Sales of Nebraska has NOS GE 13EM7/15EA7's for $3.
Tom
Tom
Hi Folks,
I built two of Fred's Miniblok's. Easy to build as a first tube project and still going strong. I had a conversation going with a couple of posters but I can't seem to find it. I might do a little Youtube video about the build, and my thoughts on this wonderful little amp.
Fred's build description kept the cost down but I spent more money than perhaps I should have for something that in my butterfingers might have turned out crap. Luckily for me it all turned out fine, and as a first project I would recommend it to anyone...
I'm fairly sure that no-one on this site knows as little about tube amps as I do, except the self-confessed noobs perhaps, but the great thing about this forum is that if you ask, there will usually be someone willing to pitch in. I know this from experience...
The thing about flea watt amps is that it may actually produce more music than you have previously realized but it will be unheard because the sensitivity is not high enough to reproduce the microdetails.
MiniBlok II Stereo Build
I adapted Fred Nachbaur's MiniBlok II P-P amp into a stereo version. Sounds great. I have full documentation on this - just ask.
- Tubes / Valves
- pictures miniblok 1 and miniblok 2 by fred nachbaur
