Pico's Toxic Masculinity Class A Amp Chassis
2 picoDumbs
2013-09-06 9:35 am
Price will be:
250 Euro for Chassis + Handles + Internally mounted Steel Plate for mounting components
241 Euro for Chassis + Handles
For payment and ordering, follow link
Ricerca - 1HFTOXIC
You can't place an order till after January 1st, 2021.
If you're purchasing the Cardas Back Panel then you need to order these parts:
CARDAS PARTS SUPPLIED BY SONICRAFT
Binding posts
Cardas CCGR S Binding Post, Sonic Craft
RCAs SHORT VERSION
Cardas GRFA S RCA, Sonic Craft
RCAs LONG VERSION
Cardas GRFA L RCA, Sonic Craft
XLRs
Cardas CM F XLR Chassis XLR, Sonic Craft[/QUOTE][/QUOTE]
Alternatively you could use Neutrik XLR jacks.
Shorting Pins For XLR's - OPTIONAL
Cardas CGSP, Sonic Craft
If you want to use other RCAs and Binding Posts then choose the back panel with pilot holes.
The XLR cutout is compatible with either Neutrik or Cardas this is common on both back panels
Chassis Specs
10mm thick Aluminium Front Panel - Anodized Black or Silver
Dimensions
450mm wide
500mm deep
165mm tall
Heatsinks 500mm x 165mm
Heatsinks will be drilled and tapped to be compatible with all Firstwatt amps in the store (UMS spec) as well as some additional holes that use more of the heatsink real estate, as well as add the option to mount longer pcbs etc.
Back panel is predrilled and cut to accept:
Schurter IEC
Neutrik or Cardas XLR
Pilot hole to drill out to RCA size of your choice - it is suggested to use Cardas
Pilot holes to drill out to binding post size of your choice - it is suggested to use Cardas
Holes installed for handles.
4U x 500mm Toxic Masculinity Chassis
So far the list is:
Blk Dynamite x 2
Savu x 2
Mr Dewk x 2
Pico x 1 (maybe 2 if required to get to 25)
Gary S x 1 (maybe 3 if price is reduced further)
pwagner x 2 (maybe 3 if price is reduced further)
Hey Bill x 1 (maybe 2 if required to get to 25)
Super_BQ x 1 (maybe 2 if required to get to 25)
Mirio x 1 (maybe 2 if required to get to 25)
Ozorfis x 1 (maybe 2 if required to get to 25)
TungstenAudio x 1 (maybe 2 if required to get to 25)
ItsAllInMyHead x 1 (maybe 2 if required to get to 25)
Gnub x 1
Subbu k x 1
hifibluedevil x 1
BrianGasberg x 1
Gerald1951 x1
Cakyol x 1
vvs07 x 1
6L6 x 1
Theodosis O. x 1
Dennis Hui x 1
Kasey197 x 1
Sampsonite x 1
Argos x 1
wg45 x 1
dantwomey x 1
32y0 x 1
Kbergsson x 1
Analogdiy x 1
ggetzoff x 1
  • Front Panel.pdf
  • 2 x 250mm heatsink hole pattern XA30.pdf
  • Back Panel II + handle.pdf
  • Top-Bottom Panel.pdf
2 picoDumbs
2013-09-06 9:35 am
Hi Pico- Please add me to the club for one chassis. Thanks.
Here is how to order and pay.
You can't place an order just yet but here is the link
Ricerca - 1HFTOXIC
To explain:
If you are just buying the chassis you should add these handles to the order
Maniglie tonde 3 unita cromate
The full kit includes handles and an internally mounted steel perforated plate which makes mounting pcbs etc to the bottom of the chassis easier
Ricerca - 1HFTOXIC
To explain:
This has now been simplified so that the handles have been added to the Chassis Only order
