Hi!
I would like to ask for some help here.
I built 2 MM phono preamp from kits. One is discrate and with PSU, another is with IC and with battery. When I try to use them with my JLH or ZenLite amp I hear a light noise already on idle and it gets stronger on higher volume too. The noise is not a "humm", it is a "brzzzz" kind.
But! When I try these MM preamps with my factory HarmanKardon amp there is absolute zero noise!!!
I tried the followings:
- connect the LP ground to MM ground and without connection too,
- connect the PSU with and without the wall earth,
- earthing the case, and not earthing too,
- RCA's grunds insulated from each other and connected together the grunds too.
I have no idea what could be the problem.
One more info: the HK amp is in another house by my parents.
I also tried the MM preamps with my factory Yamaha amp by me and ther is the noise! Could it be something with my house electric system?
Is there any rule of thumb for phono preamp grunding and connecting?
Greets:
Tyimo
Greets:
Tyimo
