By trying to detect why a Philips GM6012 millivolt meter does not work, I have to dismantle all the shields on the outside.
Does anybody know how I can do that? At this moment I only could detached the backside of the GM6012.
youtube did not gave me any hints.
In such cases I usually take all the screw out that could be relevant for a dismantle.
Here's a site with a lot of pics that might help you:
https://www.pa3esy.nl/Philips/meetinstrumenten/html/gm6012/html/gm6012_set.html
Edit: Down that page you'll find two manuals that describe how to disassemble the unit.
Hugo
Hugo
Thank you Hugo, yes, I was aware of that wonderful site of Jan Poortman! I fact, if you visit his site and then navigate to "Ir. G. Hofstedeschool MTS", then go to
the "reunie" pictures, you will notice a person called Joop Alders........ Who on earth is that?
The only problem is that Jan did not show how to dismantle the GM6012 but only showed the result. But anyway, I have emailed him for help.
Will keep this Forum updated.
Thanks rayma, did already downloaded this pdf but unfortunately it does not document how to dismantle the case so I can have access to those pcb's inside.
PHILIPS... Why go simple while we could go complex ? This could be their motto about thier vintage audio equipment : a Philips item always had some specialties of its own in its design !
T
T
Wow! I must have completely overlooked this! Will have a close look at those pages!Seems each panel just unscrews individually.
The manual discusses all of this, see pages 16-17.
- Design & Build
- Equipment & Tools
- Philips GM 6012 millivolt meter
