recently I bought Philips CD304 Mk2 as transport for my nos DAC. Before I used different Philipses with CDM2 or 4 and was quite satisfied. But the 304's low level detail is unbelievable, probably thanks to the CDM1 transport. The first time the soundstage is as good as from record player!
However there is sibilance mainly on leading Ss in vocals, some instruments may also sound more aggressive. Unfortunately I can't tolerate this kind of distortion. I tried to fiddle (in both directions) on load of pin 14 SAA7220 by changing the first resistor of voltage divider to which the digital trafo is connected. Then I connected the whole divider+trafo via capacitor. But no succes.
Now I don't know what to do next. Replace crapy wire, including 2 connectors, from PCB to RCA connector? Change SAA7220 from another player? Buy another CDM1 player and keep this one as spare? Any ideas?
Petr
Petr
