I am wondering after removing of SAA7030 and non os mod of the CD104, SAA700 gives me 16bit out and, if i connect an external dac with PCM56, does it properly work or not? My concern is; on the datasheet of the PCM56, input frequency was specified as minimum 10mHz. CD104 quartz frequency is 4.2336 MHz. Does it make a problem
Thanks a lot!
Thanks a lot!
