Phase Linear 10" drivers
Hello!
This is my first post. 🙂
I live in Finland and my english isn´t very good.
But I´ll try. 😀
I have two Phase Linear Heavy Cast (4 ohms) subwoofer drivers; 10", 300w, 94 db, xmax +- 3mm.
Those drivers are designed for Free Air use in car.
Is there any use for those drivers at home?
And what is right enclosure for Free Air subs?
Thank you
Mikko.
well i dont see why not use them at home the enclosure might be a problem but u coul try to calculate the parameters of the speaker to figure out the size box neded but u probably need the instructions that list the parameters if u have them (x-max qts vas qts) stuff like that
Those Phase Linears are junk... please mail them to me for proper disposal. You can even mail them to my friend that is from Finland. 😀
Actually, I've never thought about using free air subs intended for the car in the home... Actually, I don't know that much about free air subs in general. If a certain free air sub sounds good in the car and goes fairly deep, will it lack bottom end in the larger space of the home? Or does the free air design negate this entirely?
